Gpm
Results 1 to 3 of 3
Thread: Gpm
    Default Gpm
    Hello friends,
    I am new in the field of power washing so I want to know some more information about the GPM (Gallons per Minute), If anyone knows then share it with me.
    Thanks
    Default Re: Gpm
    Just remember this.....the higher the GPM the faster you can clean. In other words, you could have two 3500 PSI machines, (one is 3.5 GPM and one is 8 GPM). Your 8 GPM machine will clean way faster than the 3.5 so you're more efficient and since time is money, the higher price of the 8 GPM machine will eventually work in your favor. A lot of people start out with a smaller GPM machine and eventually work up to a larger machine once they start getting bigger jobs. Both will still clean so it's just a matter of how FAST you want to get the job done.
    Exceptional Exteriors LLC
    Sterling Rogers
    281-475-5257
    Default Re: Gpm
    Sterling nailed it. Another thing to point out is if you go over 4/5.5 GPM you will need to carry a buffer tank so the PW gets enough water.
    Sent from my iPhone using Tapatalk
    Mebane Pressure Washing, LLC
    www.mebanepressurewashing.com
    Tags for this Thread
