mbpowerwashing
Hi all,
So I want to add downstreaming injector in my battery of tools so Im not only relying on my M5 X-JET.
Couple of questions; I was looking at the " Adams Adjustable Acid Injector 2.1mm QC Kit (Plug Inlet and Socket Outlet) 3-5 GPM" item that sunbite has to offer. Figured I'd get the acid option if I ever need to apply an acid application (probably) -
So I ask; how would I calculate how much is being applied out of the gun? is it in percentages? So if I make a solution and draw from it and set the injector to 20%, would I be correct to say if the draw solution is a final 8% then draw up at 20% would give me a 1.5% of bleach coming out of my wand.
Am I calculating this correctly?
Also, if I want to use ratio's instead of percentages can I do this with this unit?
Thanks again.
Thanks again.
