Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Hardwoods
Results 1 to 6 of 6
Thread: Hardwoods
  1. #1
    Default Hardwoods
    Is there somewhere I can go online to learn more about hardwoods and the different species. I feel like I understand the oiling process. Is that the same about hardwoods across the board? What about stripping using powersolve?
  • #2
    Default Re: Hardwoods
    Boy Don its post like yours that make Thads day
  • #3
    Yeah, there are tons of threads on The Grime Scene on various hardwoods..... ;)
    Beth
    See Dirt Run!TM Inc.
    Log Home Maintenance & Restoration, Decks & House Washing
    Beth Borrego & Rod Rodriguez
    Office: 301-540-1243
    Germantown, MD * MHIC# 86481 * VHIC# 2705-126609 * BBB
    The Grime Scene BBS Forums
  • #4
    Default Re: Hardwoods - cleaning ipe decks
    Don, the process is the same for hardwoods such as ipe, garapa, mahogany and all the various species. What give the hardwoods their color is their high level of natural sugar and oils. If you do a two step cleaning process, which I highly recommend, the deck is going to look a little washed out because you are removing those resins. When you oil the deck, your staining product will basically fill in the void and the color will come back.
    If your project is only gray or has little to no stain on it, cut the Powersolve 50/50. There is also no need to go hardcore on the acid. Mix it strong (10 oz per gallon) and downstream it.
    PressurePros, Inc
    Pressure Washing Companies
  • #5
    Who's Doing Wood here?
  • #6
  • Thread Information
    Users Browsing this Thread
    There are currently 1 users browsing this thread. (0 members and 1 guests)
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
    Single Sign On provided by vBSSO
