Reclaim units, anybody know much about them?
Results 1 to 10 of 11
Thread: Reclaim units, anybody know much about them?
    Default Reclaim units, anybody know much about them?
    I might have an oppurtunity to get into some commercial wok that requires reclaiming. Didnt know until recently the state requires it
    Anybody know of some good units or something I can make myself?
    Im looking at this one right now
    http://www.hydroteksystems.com/rec-hydroloop.htm
    But from what I understand, I cant filter and re-use the water, but if its filtered can I drain it into the sewer?
    Any input would be appreciated.
    Thanks.
    Chad Johnson
    East Tennessee Power Washing
    Knoxville, Tn.
    www.easttnpowerwashing.com
    Default Re: Reclaim units, anybody know much about them?
    Chad,
    There's a lot of info out there on types of equipment, regulations, BMPs, and so on. First, when you refer to "sewer" I'm assuming you mean sanitary sewer and not storm sewer. Storm sewer discharge is almost universally NOT acceptable. As for you local sanitary sewer, you'll most likely need some type of permit from the sewer authority before you can discharge there. Picking up the water is easy and cheap (vacuum, sump pump, etc.). getting rid of the water legally is a bit tougher. I'd suggest doing a search at TGS in the environmental forum. Lots of reading over there, and links too.
    As for the hydroloop, I think it's a decent entry-level unit, but it will depend on the volume of work you're going to perform.
    Mike Schoeben
    A-1 PRESSURE WASHING, LLC
    Serving the Twin Cities Metro area since 2000
    763-300-7128 / Champlin, MN
    http://www.a-1pressurewashing.com
    Quote Originally Posted by Big Mike View Post
    Chad,
    Thanks for helping him out Mike....I appreciate all your help over here at UAMCC.
    [B]Carlos Gonzales[/B]
    [B]New Look Power Wash
    [URL="http://www.newlookpowerwash.com"]Pressure Wash in California[/URL][/B]
    [URL="http://www.newlookpowerwash.com/category/uncategorized"][B]California Pressure Washing Blog[/B][/URL]
    [B][URL="http://www.newlookpowerwash.com/california-pressure-wash-blog/pressure-wash-services-in-san-francisco.html"]Pressure Wash Services in San Francisco[/URL][/B]
    Chad,
    It was nice talking to you last. I hope I helped out with what you have going on. Good luck with the Property Manager and as I said feel free to contact me anytime. Talk to you later.
    Thanks for the response guys.
    Thanks for your help again Rob. Definately helps get my foot in the door.
    I left the PM a message and Im waiting for a response.
    Chad Johnson
    Knoxville, Tn.
    Chad,
    no problem at all. Let me know how it works out for you.
    Mike I was also looking at hydro tek.....if its entry level what would be a good unit to buy? Azv88 was the unit I was looking to buy. I am about an inch from getting out of landscaping and just going prowash....any input would be nice
    Lou Zehnder
    Nashville Tn.
    Pressure Washing Nashville Tennessee
    Lou,
    The biggest thing to look for in a reclaim unit is the volume it can handle. If you're doing smaller jobs, and running one rig, the Hydrotek should work fine for you. If you're trying to reclaim wash and rinse water from several machines, and pieces of equipment at the same time, you'll need something that can handle the volume of water its taking in. If your vacuum and OWS can't handle it, you'll likely have water going where you don't want it, or you'll end up stopping washing, and waiting for your reclaim to catch up. Time=money. There's some decent equipment available, and it doesn't have to cost a fortune. Many have built high volume vacuums for a lot less than you could purchase one. I don't want to endorse any particular brand or type, but here's my box truck recovery setup:
    Sirroco PEV2 vacuum / portable
    Sirroco OWS 10-200 / truck mounted
    8000 watt generator / truck mounted
    275 gal tote for reclaimed H2O
    Mosmatic vacuum surface cleaner
    Plus all the other stuff like sump pumps, oil socks, sludge pump, drain covers, berms, oil dri, shovels, brooms, squeegees, etc, etc.
    This allows me to run many different configurations of recovery. My machines on that truck put out 5.5gpm, and the OWS will handle 10gpm.
    Most often we don't use the vacuum surfacer, we'll run Big Guy's for speed and rinse with a wand. We can run this setup for 8 hrs+ before having to clean filters on general cleaning (except the vac filter). Your biggest concern should be pre cleaning the area to reduce debris entering the system.
    Mike Schoeben
    How much is the hydrotek you linked to? I hate equipment sites, they rarely advertise prices.
    Scott Davis
    Confident Roof Cleaning
    Donny Jackson
    Guest
    __________________
    Mike Schoeben
    I use a back pack blower ( now ) Helps alot
  • Page 1 of 2 1 2 LastLast
