Scott - why not also make room for your airless (painting) and keep it a washing/paiting vehicle? Sale the customer not only on the washing but also on the painting to.
Just my .02
I have a 12 enclosed and originally had mine set up with power tools and spray rig. Even though I don't keep as many chems in the trailer at one time corrosion is definitely a factor. I had to move all my tools, even hand tools out because of rust. Power tools can go quickly and I did not want to take a chance on ruining the 595. If you could section off the front end of a longer enclosed trailer I think that would be ideal. My goal was to have a mobile paint store with everything I needed. Acids, SH, and sodium hydroxide doesn't play well with others.
On a side note; I looked into an epoxy floor application for custom garage floors this year. Part of the agreement was a turn key trailer set up. Here is the inventory list that the trailer came with including work benches, cabinets, tie downs, etc. Almost nirvanna.
Stone To Foam Trailer:
• 12’ Custom Blue, Single-Axle Trailer w/extended 4 foot “V” nose
• Beaver-tail style rear entry door
• Display Graphics featuring Dealer’s name
• Fully insulated walls and ceiling
• ¾” Plywood Floor surfaced w/high-performance vinyl coating
• Chrome wheels
• Thermostatically controlled electric heater
• Side man-door
• Skylight vent (1)
• Extended-height roof
• Spare tire
• Electric brakes
• Aluminum stone guards
• Door locks
• 12V lights
• Stabilizer jacks
• Hydraulic bottle jack
• Tie-down security straps
• GFI 110V outlet
• 110V light switch
• 30# Fire extinguisher, mounted
• Explosion-proof lighting system
• Cabinets
• Solvent cabinet (45-gallon)
• Wired for 110V electrical service
• Gas bottle holders
• Wheel chocks (2)
• Spring grip broom organizer
• Handy hooks
Application Equipment:
• Cobra® Multi-Prep concrete floor preparation machine (110/220 switch)
o Dust Control Vac w/floor tool
o Sanding heads (set of 3)
o Scrub-brush heads (set of 3)
o Wire brush heads (set of 3)
o Steel cutter scarifier heads (set of 3)
o Carbide floor scraper heads (set of 3)
o H/D quick-grind diamond heads (set of 3)
o Ultra-quick diamond grinding heads (set of 3)
o 60-grit sand disc (9)
o 100-grit sand disc (9)
• Edge Grinder
• Roll-on/Brush-On Equipment
o Caulk gun
o 5-gallon buckets w/lids (3)
o 9” x 3/8” roller covers (4)
o 9” x 1/4” roller covers (4)
o 9” roller cages (2)
o Roller extension handles (2)
o Large rolling pans (2)
o Rolling pan liners (6)
o Polypropylene spiked shoes ¾” (2 pair)
o Squeegee
o Canvas drop cloth
o 1-gallon mixer
o 2” Bristle brushes (4)
o Graduated stack cups (6)
o Gallon cans (3)
o M.E.K. (2 gallon)
Exh. E
Page 1 of 3
Misc. Tools:
• 5-gallon jiffy mixer (1)
• Flat/Phillips adapter for drill
• Lighter
• 50’ extension cords (2)
• 100’ extension cords (2)
• 3 prong electric adapter (3)
• Grounded T adapter 3/way
• Belt sander w/80-grit paper
• Electric leaf blower
• Flashlight
• 24” push broom
• Deep dustpan
• Bench brush
• Yellow sweep broom
• 32-gallon trash can (1)
• 33-gallon contractor trash bags, 12 ct
• 4’ Fiberglass ladder
• 25’ measuring tape
• 17-Compartment parts box (1)
• Master locks (3 pack)
• 20” Box fan
• Pole sander bases (2)
• Pack 80-grit for pole sander
• Knee pads (2 pair)
• Temperature & Humidity gauge
• 3” stiff putty knife
• 3” flexible putty knife
• Wire brush – stiff
• 24” Masking paper
• Paint paddles/stir sticks (25)
• 2” Masking tape (6)
• Plastic sheeting roll
• Bundle of Rags, 12lb.
• Utility knife
• Utility knife blades (100)
• Mr. Heater® gas/propane infrared heaters (3 units)
o 2 hanging infrared heaters
o 1 stand-up portable ceramic heater
o 30# Propane cylinders, filled (2)
o 20# Propane cylinders, filled (2)
Misc. Tools Continued:
• Toolbox
• Screwdrivers, 8pc
• Set of pliers w/wire cutters
• Crescent wrench set 8”, 10”, 12”
• Electric ½” variable speed drill
• 102-piece tool set
• Rubber mallet
• 16oz claw hammer
Safety Equipment:
• Cartridge respirator (2)
• Safety goggles (2 pair)
• Tyvek suit (2)
• Dust Masks (3)
• 1 Box (100) latex gloves
• Solvent gloves (2 pair)
• Industrial first aid kit
• Eye-wash station
• No Smoking signs (2)
• Fire Extinguisher sign (1)
• Cotton Gloves (4 pair)
Marketing / Support Tools:
• Marketing brochures (100)
• Samples
• Tech Sheets
• MSDS
• Quotation sheets (5)
• Yard signs (5)
• Sample Case (1)
• Customer Order forms (5)
• Warranty sheets (5)
• Stone to Foam logo shirts (2)
• Stone to Foam logo hats (2)
• Stone to Foam logo work T-shirts (2)
• Dealer Support CD
o Business Card template
o Letterhead template
o Logos
o Yellow Page ads
o Case Histories
o Flyers
o Magazine ad
o Photos
o Material Order Forms
o Sales PowerPoint Presentation
Exh. E
Page 2 of 3
Chemicals & Products
• Floor Chips (two 50-lb boxes)
• STF-200 (4 kits)
• STF -707 Clear (4 gallons)
• STF- Thinner (1 gallon)
Cabinet Tools * SEE NOTE BELOW
2 hand clamps- holds door jig in place and pulls cabinets together.
5/16” hexhead driver- for Tech screws
Bits:
o 3/8” drill bit
o 1/8” drill bit
o 5/16” drill bit
o 3/16” drill bit
o 1/16” drill bit
o ½” paddle bit
o Screw driver bits- #2
o Extra long #2 screw driver bits install closet rod
o Magnetic Extension for screw driver
Levels- 4’ and 2’
Squares- Framing/Combination/Speed
Rubber mallet – non-marring
Band Cutter (or Tin snips)
Nail set
Pry Bar
Chisel
Hand saw
Chalk line with chalk
Brad Nailer w/small compressor
Brads for nailer
Pencils
Sharpie marker (for marking steel)
Sand paper
Alcohol
Shims
Carpenter Glue
Hand Miter box with saw
2 saw horses
Rechargeable VSR drill and charger
