Powerwashstore Weekly Special
Look to the powerwashstore.com for weekly specials and discount pricing that will save you $$.
This weeks special
Whisper Wash Ground Force Surface Cleaner
Part # 9407 $709.95
Regular Price $749.95
Easy storage and flexibility. This 24" diameter surface cleaner is made from a heavy duty aircraft grade aluminum for extreme durability. Equipped with 4 heavy duty casters the Ground Force is easy to move in any direction. The Whisper Wash Ground Force has a flip and fold handle for easy storage and is equipped with a durable nylon skirt, 4,000 psi rotary head rated to 212 degrees F and flows to 10gpm. The heavy duty arms spin at speeds up to 2500 rpm for even and fast cleaning.
Sale ends 1/8/11-And yes it still qualifies for FREE SHIPPING!
Contractor series pressure washer sale 3500 psi @ 4 gpm
1/16/11-1/22/11
Power Wash Store Contractor Series Pressure Washer
3500 psi @ 4 gpm
Part # CS4035B $1295.00
Regular Price $1425.00
This item does not qualify for free shipping.
Standard Features
•Solid, lightweight, aircraft grade aluminum frame with handle has no welds to fail
•Limited lifetime warranty on frame
•Inline mesh filter screen
•Adjustable trapped pressure unloader
•Low oil protection shutdown switch
•Pneumatic tires on wheeled cart style frames
•Dual shock absorbing foot pads on front
•3/4" cold rolled solid steel axle
•Commercial grade Honda engine
•Heavy duty General Pump
•3 V-Belt drive
•Thermo-sensor to prevent overheating of pump during bypass mode
Sirocco 21" Vacuum Recovery Surface Cleaner
1/30/11-2/5/11
Part #SC21V $1525.00
Includes Free Shipping
Our Closed Loop Cleaning Systems are revolutionary in enviro-compliance and time savings. When the pressure washing and wash water control are done simultaneously you have a net increase in work speed which quickly pays for the equipment. Control over spray from pressure washing sidewalks, warehouse floors, tile surfaces and more. Sanitize with up to 250 degree F as fast as you can walk, and have dry floors in minutes. Add our filtration for Re-Use and have the ultimate in water conservation too.
• Quick-couple trigger handle for easy removal and attachment of spray wand
• Hand held “Sidekick“ cleaning wand conveniently located onboard for cleaning in corners and tight areas
• High pressure water filter insures clean spray nozzles
• Triple vacuum intake tubes remove 90-98% of dirty wash water during cleaning process
• Stainless steel outer shell for added strength and rust resistance.
• Wheeled carriage for easy portability over uneven terrain and to minimize or eliminate back strain.
Briggs and Stratton 18 hp engine with muffler
2/6/11-2/12/11
18 hp Briggs and Stratton Engine
Shipping not included
Briggs and Stratton 18hp v twin Vanguard. Equipped with electric start, Top mount oil filter side muffler, 1" shaft, 20 amp high capacity charging system-Hot box ready.
Features:
• Dura-Bore™ cast iron cylinder sleeve for extended life
• Float carburetor for consistent easy starting
• Maintenance-free Magnetron® electronic ignition for quick, dependable starts
• Dual-Clean™ air cleaner pleated paper filter with a foam pre-cleaner ensures maximum protection for extended engine life
• Full pressure lubrication with spin-on oil filter assures controlled lubrication for extended component life
• Overhead valve design (OHV) for cooler operation and longer valve life
Repower guidelines
Pro-Max Series 8 gpm at 3000 psi Pressure Washer
2/13/11-2/19/11
Standard Features
•Aircraft grade aluminum frame with dual handles has no welds to fail
•Lifetime warranty on frame
•Easy access tip hose and gun holder on handle
•EZ-Start feature
•Epoxy powder coated frame finish
•Gates 10,000 hour polychain cogged belt with 2 year warranty
•Water inlet plumbed for tank feed
•*Adjustable trapped pressure unloader
•Engine oil drain hose for easy, no-mess maintenance
•Oversize pneumatic tires
•Dual spring cushioned shock absorbing foot pads
•Honda commercial grade gasoline engine
•Low speed belt driven General Pump
•Thermo-sensor to prevents pump overheating during bypass mode
•Includes 6 gallon remote poly fuel tank
•Electric start
•Marine grade battery box with battery
Standard Accessories
•Spray gun with insulated wand and quick connects
•50' length of high pressure hose with quick connects
•Maxi-flo 20 % chemical injector with quick connects
•4 color-coded quick connect spray nozzles: 0°, 15°, 25°, 40°
•1 color-coded quick connect chemical nozzle
Available Options
*Block Mounted K7 Unloader add $110.00
**Skid mount frame option available
Ultra Hot Vertical Hot Box Pressure Washer Heater
2/20/11-2/26/11
Rated to 6.0gpm @ 4000 psi.
Used in conjunction with an existing pressure washer. All units are completely factory assembled, tested in the USA, and delivered ready to operate.
STANDARD FEATURES
• Rugged powder coated steel frame
• Super efficient schedule 80 coil with one-piece molded insulation combustion chamber
• Stainless steel coil wrap
• 9 gallon poly diesel fuel tank with fuel filter
• Reliable Beckett burners
• Adjustable thermostat temperature control
• Safety pressure relief valve
12 volt models, require 20 amp continuous power supply (not included).
