Powerwashstore.com-Daily Specials
Power Wash Store- Specials Updated Daily -Parts-Equipment Pressure washers
1/13/11
McCauley Spray Lance
48" Lance with Molded Grip, 1/4" MPT Inlet & Outlet, 10 GPM, 4,000 PSI.
Lances/Flexible
Flexible lances allow the operator to bend the lance in multiple directions and steep angles while keeping the gun in a single position. This lance is a good choice for those in car wash operations or for those who degrease engines and other equipment. One style of flex lance is equipped with two solid pipes on each end with a flexible rubber grip in the center. Under this grip is a short section of flexible hose that is connected to each side of the pipe. The end of the lance can be bent in any direction and moved easily while the water is spraying. A second style is the McCauley spray lance. It uses a section of hose encased in a flexible metal housing. This unique housing allows the operator to bend the lance to a particular angle and have it maintain its shape under pressure. This feature enables the operator to attach the lance to the end of a pipe for spraying at strange angles. This is especially useful for hood cleaners who often have to spray ducts that turn in many directions. It can also be used for cleaning gutters.
Trombone dual nozzle holder
1/14/11
Trombone Nozzle Holder
Rated to 11 GPM @ 4,000 PSI
High Pressure Nozzle goes in the top. Low Pressure Nozzle goes in the bottom.
When you what low pressure soap simply release the trigger & reach up and pull back on the piston. To return to high pressure return the piston to the forward position.
General Pump Model EZ4040G Pump Sale -Free Freight
1/17/11
General Pump - Model EZ4040G
General Pump- EZ4040G $299.95
Includes Free Shipping
This is a new General Pump replacement pump. Rated at 4 GPM up to 4000 psi.
• Standard SAE J609 gasoline mounting flange for up to 13 hp engines
• Forged brass manifold with an exclusive lifetime warranty and 3:1 hydrostatic rating
• Die-cast, anodized aluminum oil-bath crankcase
• Innovative one-piece plunger design to eliminate water entering crankcase
• Premium roller bearing
• 5% reduction in crankcase load compared to standard 3,000 PSI, 15 mm pumps
• Unitized stainless steel inlet and discharge valves
• Available in “L” left-handed versions
Click on the link to get a PDF version of the pump specifications.
EZ4040G
Cat Pump Model 56 - free shipping
1/18/11
Cat Pump - Model 56
Cat Pump- 56 $1078.70
5.5 gpm up to 3500 psi @ 1210 rpm. This is a new cat replacement pump. Click on the link to get a PDF version of the pump specifications. CAT56
[FONT=Myriad Pro,Myriad Pro][FONT=Myriad Pro,Myriad Pro][FONT=Myriad Pro,Myriad Pro][FONT=Myriad Pro,Myriad Pro][FONT=Myriad Pro,Myriad Pro][FONT=Myriad Pro,Myriad Pro]FEATURES[/FONT]
[FONT=Myriad Pro,Myriad Pro]1- Triplex design delivers high efficiency and low pulsation.[/FONT]
[FONT=Myriad Pro,Myriad Pro]1- Durable dual V-Packings are lubricated and cooled by pumped liquid.[/FONT]
[FONT=Myriad Pro,Myriad Pro]1-Pre-Set Lo-Pressure Seals provide secondary protection against external leaks and require no packing adjustment.[/FONT]
[FONT=Myriad Pro,Myriad Pro]1- Special high density, polished, concentric plungers provide a true wear surface and extended seal life.[/FONT]
[FONT=Myriad Pro,Myriad Pro]1-Optional HT, FPM elastomers for compatibility with many liquids and temperatures up to 200°F.[/FONT]
[FONT=Myriad Pro,Myriad Pro]COMMON SPECIFICATIONS[/FONT]
[FONT=Myriad Pro,Myriad Pro]Bore.............................................. ..................................0.708" (18 mm)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Inlet Pressure Range...........................Flooded to 60 psi (Flooded to 4 bar)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Crankcase Capacity.......................................... ..........25 oz. (0.75 l)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Standard Liquid Temperature................................160°F (71°C)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Above 130°F call CAT PUMPS for inlet conditions and elastomer recommendations.[/FONT]
[FONT=Myriad Pro,Myriad Pro]Inlet Ports (2)............................................... .........1/2" NPTF (1/2" NPTF)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Discharge Ports (2).............................................3/8" NPTF (3/8" NPTF)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Shaft Diameter.......................................... .................0.945" (24 mm)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Weight............................................ .........................29.25 lbs. (13.3 kg)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Weight w/Gearbox........................................... ......36.8 lbs. (16.7 kg)[/FONT]
[FONT=Myriad Pro,Myriad Pro]Dimensions........................................ ...13.93 x 8.2 x 6.41" (354 x 208 x 163 mm)*See Gearbox Data Sheet 8051-8078 for maximum engine rpm.[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
[/FONT]
General Pump Model TS2021 - free shipping
1/19/11
General Pump TS2021 $439.95
5.6 gpm rated up to 3500 psi
• The preferred pump frame in the pressure cleaning industry
• Large-capacity, die-cast, anodized aluminum oil-bath crankcase
• Over-sized connecting rods for maximum life
• Heavy-duty tapered roller bearing
• Solid ceramic plungers with continuously lubricated packings
Click on the link to get a PDF version of the pump specifications. TS2021
General Pump K7 Unloader - Free Shipping
1/21/11
General Pump K7 Flow Actuated Unloader
K7 Unloader $69.95
• Features all stainless and brass internal parts
• New design reduces sensitivity to entrapped air
• No external moving parts or springs
• Eliminates high pressure in all lines while unit is in bypass mode
• Bypass restrictor eliminates pressure peaks during bypass
• Unique balanced piston design permits precise pressure adjustments
• Simple design for easy maintenance and service
K7 Flow Actuated Unloader, 3,500 PSI, 165 Degree F, 3/8" FPT Inlet, 3/8" MPT Outlet, 3/8" FPT Bypass
PDF Breakdown
PA Pressure Compensating Unloader - VB10
1/25/11
PA - VB10 Unloader # 1011 $71.95
PA Model VB10 soft touch unloader, feels like a flow actuated unloader but adjusts like a pressure actuated unloader. Pressure compensating, 3,500 psi, 8 gpm, 195 degrees F, 3/8" inlet, outlet, and bypass.
PDF Breakdown
Heavy Duty Premium Hose Reel Swivel - Rapid Reel
2/3/11
Heavy Duty Premium Hose Reel Swivel # 8100 $36.42
Qualifies for Free Shipping
This heavy duty premium hose reel swivel is rated for 5,000 PSI and comes with a 2 year manufacture warranty. The all Stainless Steel rotor center insert and the unique inner seal is designed for extra long life. Fully rebuild able this hose reel swivel is compact and durable. 3/8" FPT inlet for high pressure hose and a 1/2" FPT outlet to the hose reel.
Compact foam nozzle
2/4/11
Compact Foam Nozzle Attachment
Compact Foam Nozzle #6256 $28.86
Attach the compact foamer nozzle to the end of your lance to create a thick clinging foam for extended dwell time and increased chemical action. Stainless steel, aluminium and brass construction. 5" long 1" diameter, flows to 5 gpm, 195 degrees, 2500 psi, includes 4 and 6.5 nozzle.
1/4" FPT inlet.
Honda - Briggs air and oil filters
2/10/11
Briggs and Honda Filters
Briggs Air Filter (16-18 hp) # 1256$12.61
Briggs Oil Filter (16-18 hp) # 1253 $9.19
These are original Honda and Briggs and Stratton replacement parts from the factory not cheap imitations.
  • Briggs & Stratton Air Filter, Fits All Vanguard Engines
  • Briggs & Stratton Oil Filter, Fits All Vanguard Engines
  • Honda air filter for GX610/620 newer style rectangular filter. (18-20 hp)
  • Honda Oil Filter, Fits GX620 or GX670. (20-24 hp)
Extreme Duty Siphon Pump
2/14/11
This extreme duty pump is designed for acids and corrosives. These are the industry’s #1 selling siphon pumps. Transfer rate of up to 7 gallons per minute. Intake pipe may be cut down for 5, 15, or 30 gallon drums.
Suttner ST-1500 High Pressure Trigger Gun
2/15/11
The industry standard trigger gun. This gun provides a comfortable grip for smaller and larger hands alike. Rated for12 GPM at pressures up to 5000 PSI and 300 Degree Fahrenheit water. This trigger gun is equipped with a 3/8” FPT inlet and a 1/4" FPT outlet. Weight 20 ounces.
