Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962
What would you use for dirty sill cleaning on the outsides?
Results 1 to 7 of 7
Thread: What would you use for dirty sill cleaning on the outsides?
    Default What would you use for dirty sill cleaning on the outsides?
    I plan on using this
    Tony Evans
    A New View Exterior Cleaning
    UAMCC President
    319-325-9475 Call or Text
    tony@anewviewia.com
    Default Re: What would you use for dirty sill cleaning on the outsides?
    Did you test it out, and how did the test go?
    Went well. I could use a bigger pump for my pure water system but even so it did a better job cleaning sills and patio door thresholds than using my water fed pole jets.
    Tony Evans
    UAMCC President
    tony@anewviewia.com
    Contributing Member No Posting Eric Seitz's Avatar
    Dec 2011
    113
    Blog Entries
    8
    What size pump are you using?
    I'm using a Wayne transfer pump on my pure water system right now but will be upgrading to a better one this year. I could use my Tommy pump from Powerwashstore and get plenty of pressure out of my pure water barrel.
    Tony Evans
    UAMCC President
    tony@anewviewia.com
    Dec 2011
    113
    Blog Entries
    8
    How many gl a min.
    Since it's a transfer pump it doesn't have a gpm rating on it. It will boost the line pressure up to an additional 50psi so on jobs where I'm only getting 30 psi from the tap I can boost it to 80 psi and have the pressure I need for good performance out of my ROs. It's not ideal and I'll be upgrading this year to a better booster pump box.
    Tony Evans
    UAMCC President
    tony@anewviewia.com
