Results 1 to 7 of 7
Thread: Any idea what this is?
    Default Any idea what this is?
    Default Re: Any idea what this is?
    Inside or outside? Weird how it stays away from the white strips and border like it was taped of and it's overspray.
    Sent from my iPad using Tapatalk HD
    Chris Dubbs
    The Wash Wizards
    Fishers In.
    It's in between the glass......
    was this before or after you washed? I had a client once who had some leaky windows and some of them were so bad that they were stained white.
    she asked if I could get it out... I told her I could try but probably not.
    She ended up replacing them.
    Tiger Pressure Wash
    Baton Rouge, LA
    (225) 284-4527
    Tiger Pressure Wash is a Professional Baton Rouge Pressure Washing company, servicing the Greater Baton Rouge area since 2012
    batonrouge.pressurewashing.net
    www.facebook.com/tigerpressurewashbatonrouge
    https://www.youtube.com/watch?v=YMnO-PblKXo
    Guys this is common on lower end windows. It's a low e reaction. Low E is a metallic spatter coating applied for energy efficiency. The problem is that it doesn't work and play well with others. If there is any debris or oils (from finger or hand contact) on the surface it's applied to it reacts. This reaction can be days or even years after the unit leaves the factory. I've only ever seen it on units with tempered glass as many manufacturers don't clean the glass properly before tempering and that leaves contaminants for the coating to react to on the surface.
    It should not be confused with what is termed a blown seal as that is a moisture condition that causes corrosion inside the unit that is milky white in color.
    Tony Evans
    A New View Exterior Cleaning
    UAMCC President
    319-325-9475 Call or Text
    tony@anewviewia.com
    Thanks Tony....the customer is contacting the company that installed the windows to see of they can find out about warranty issues. Thanks for your advice...
    Just doing my part and passing on what I've learned. It's nice to be able to help.
    Tony Evans
    UAMCC President
    tony@anewviewia.com
