David Simmons
Hi, My mitm hot water diesel unit is smoking , to the point I'm having to leave my hospital job's because of complaints in the upper floors.
My plan is to replace the insulation, as I wasn't getting spark and pumped diesel into the unit for a while, while the machine was running with the burner still on, it saturated the bottom of the cyclinder, last month I noticed smoke coming out 24 hours after I used the machine, it was super hot to the touch at the bottom.
I'm headed to get insulation and pull the coils out, I've never done that before, should be fun.
Thanks,
David in Florida, pressure washer
Thanks,
