Larry Hinckley
Delco Cleaning Systems of Fort Worth is releasing a new line of gasoline engine pressure washers that will revolutionize the way mobile power wash contractors operate. More than 6 months of planning and testing has gone into these changes.
2009 RK-43 Style Frame Series
Hot High Pressure Washers
Featuring EBP™ – Enhanced Burner Protection™
• Burner Power Light
• AIP™ – Advanced Igniter Protection™ safeguards against:
o Electrical Failure, Engine Failure, Low Voltage
o Fuel/Water Separator – Protects against
? Water and Debris in the burner fuel
Advanced Diagnostics Protection™
• Diagnostics Lights: Burner Fuel Solenoid, Pressure Switch, High Temperature Switch
Enhanced Pump Protection™
• Thermal Pump Shutdown with Override Switch
• Automatic clutch operation for extended life and reduced maintenance on specified models
Features and Benefits:
• Electric Start Engines: Vanguards have pull start backup, 12V 20 amp charging system, Low Oil Protection at 5 psi, will not start without oil.
• 12v Beckett Burner, Electrical Protection: cut-in: 5 psi oil pressure & 12.8 v; cut-out 11,8 v
• Schedule 80 Coils, High Temperature Limit Switch
• Gasoline Engine; Diesel, Kerosene, or Home Heating Oil Fired Burner
• Belt driven General TS2021 Tri-plex Ceramic Plunger Pump
• Block Mounted Pulsar Unloader Valve; Pop-off Safety Valve, Powder Coated Frame
• Stainless Steel Burner Heat Shield and control panel.
• 2-gallon float tank with garden hose hook up with before the pump chemical injection for high pressure chemical metering.
• 16 Gallon Poly Diesel & Gasoline Fuel Tanks, fuel usage: 1 gph gasoline, 2 gph diesel.
• 50’ High Pressure Hose, Trigger Gun, and Wand Assembly with QCs
• Four 5.5 High Pressure Spray Nozzles with QCs: 0°, 15°, 25°, & 40°
• 5-Year Limited Warranty, Diagnostics Lights, Hour Meter, Pressure Gauge
• See video on www.youtube.com , search term “RK-43 Delco Cleaning”.
• RK-43 Frame Style: RK-41, RK-42, RK-43, RK-45, RK-8300
• L = 44”, W = 38”, H = 45”, Shipping Wt. = 630 lbs
• Optional Wheel Kit…$450.00
Contact Mark Austin at 800-211-0289
