Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968
Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2962
Amount of solution used on average per job?
Results 1 to 8 of 8
Thread: Amount of solution used on average per job?
  1. #1
    Default Amount of solution used on average per job?
    I use the 55 gal tanks with my soft wash system. It took me a whole tank to wash a 1560 sq ft house and another whole tank to spray the roof 6/12 pitch. Is this the norm or am I applying too much or too little?
    Matt Hayes
    Power Restorations Pressure Washing
    334-799-2747
  • #2
    Default Re: Amount of solution used on average per job?
    I don't have a Soft Wash System setup but via D/S 5-7 gals. for the house and maybe 30 gals. max for the roof using my dedicated roof pump.
    Rance Tilley
    Paducah, KY.
    270-366-5254
  • #3
    For the the house that sounds a little much, for the roof it might be ok. Knowing how dirty the house and roof were and what your mix ratio was would help me to give you a better answer.
    Doug Rucker-Owner/Operator
    Certified NCE Instructor
    We own and operate a School for Pressure Washing, Roof Cleaning, and Soft Washing http://www.pressurecleaningschool.com
    Check out our ONLINE PRESSURE WASHING SCHOOL with over 160 videos https://www.pressurecleaningschool.c...ashing-school/
    Free FREE Events www.uamccevents.com
  • #4
    I would think you are spraying a little to heavy. When i do a roof and a house I may go thru 60 gals max total.
    Roof Cleaning Michigan
    Fleet Washing
    Pressure Washing
    dan@yourroofcleaner.com
    http://www.facebook.com/yourroofcleaner
    [IMG]file:///C:/Users/Dykstra/Desktop/Roof%20Cleaner/2013%20ASK%20THE%20SEAL%20NEW%20LOGO%20-%20SEAL%20OF%20SECURITY.jpg[/IMG]
  • #5
    I have done two roofs. One not so dirty the the other was about 2400 ft and only a couple of sections were real dirty. I used 11 gal shock 32 oz roof snot and 5 oz lemonade and about 40 gal water. Have applied 3 times to real dirty spots. The spots are not fully restored yet. Thankfully it is a family practice house. I think it is pecan tree drips or something that sticks well.
    Matt Hayes
    334-799-2747
  • #6
    65 gallons for roof average, and 3 gallons house wash average for me. I X-jet my house wash.
    Sent from my iPad using Tapatalk HD
    Chris Dubbs
    The Wash Wizards
    Fishers In.
  • #7
    I think you're just spraying too much chem. When I first started I did the exact same thing. I still had streaks and just kept applying. The forums helped tremendously and, with trial and error, I learned to spray thinner coats and use a lot more patience.
    Today, on a 1600 SF home, with moderate stains, I would probably use 10 gallons of SH and 25 gallons of water on an asphalt shingle roof. the 35 gallon mix should do the job.
    The house would depend on the cladding but probably a 1-2% mix and I would use about 10-15 gallons.....it really does not take much on a house wash.....
  • #8
    Thanks you all!
    Matt Hayes
    334-799-2747
  • Thread Information
    Users Browsing this Thread
    There are currently 1 users browsing this thread. (0 members and 1 guests)
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
    Single Sign On provided by vBSSO
