Eric Holmes
Hello everyone,
I would like to know if there is any procedure to mixing you cleaning solution. Right I am using "Stick Up" as my surfactant and SH 12% with water. What I'm noticing is, my surfactant is not going to the bottom of my solution tank and its leaving more of a SH and water mix at the bottom. I've always used as a rule of thumb to never mix water to chemical and always add chemicals to water. Therefore when I make my solution I fill my water first, then add my SH 12% and lastly add my surfactant. My question is:
Is it ok to reverse my mixture so that I have the surfactant throughout the whole mix?
