Legacy pressure washer pump sale
Bill Wilson
2 available at $750 shipped!!
[h=1]Legacy HD Pump GX Series #GX9536R.2[/h]
Legacy HD Pump GX Series - Belt Drive, 9.5gpm @ 3600psi, 1740rpm, 25mm shaft, 3/4" inlet x 1/2" outlet, 39lbs
  • Designed and engineered exclusively for pressure washers
  • 5 year limited warranty
  • Forged brass manifold with FEA computer enhanced design to increase strength in critical areas
  • Die cast aluminum crankcase with extended piston rod guides for long seal life
  • Die cast aluminum connecting rods with extended length and size
  • Mirror finish ceramic plumgers with increased thickness to resist thermal shock and corrosion
  • Industrial duty tapered roller bearings
  • Stainless steel inlet and discharge valve assemblies
  • Forged valve caps with increased O-rings to withstand leakage at high pressure
  • Dacromet coated manifold bolts for extra corrosion resistance
  • U-Seal packing assembly for long life and temperature resistance
