Bill Wilson
Stick Up-60 gallon $895 shipped to commercial address/terminal Regularly $995
1-2 Quarts to 50 gal roof mix
Stick Up Environmentally Friendly All Purpose Super Surfactant
Is a general purpose surfactant blend designed for use in cleaning solutions where more dwell time, surface wetting or foam are required. In order to meet the requirements of commercial and industrial cleaning professionals this product was designed to create high surface wetting and comply with environmental standards. Stick Up is fully biodegratable. Stick Up will not degrade the potency of most cleaning solutions. Always test for stability with new formulations.
Functioning Properties:
Applications:
May be used as a surfactant or foam booster/stabilizer in most cleaning chemical compositions including chlorine bleach, alkaline solutions, acids and other general cleaners without compromising the potency of the chemicals. Stick Up will help to boost performance, dwell time and penetrating properties as well as adding a pleasant citrus scent to cleaning solutions. Stick Up will not etch glass if left to dry and is safe for use on most surfaces.
Common uses for Stick Up:
As an additive to cleaning solutions include:
roof cleaning, hard surface cleaning, vehicle washing, floor cleaning, janitorial, sanitizing solutions, household cleaning products.
- cleaning agent
- emulsifier
- foam stabilizer
- foam booster
- viscosity booster
- acid and alkali stable
- bleach stable
Applications:
