Diesel Hydrotek Pressure Washer Sale
Bill Wilson
[h=1]Diesel SC Series Hydrotek Hot Water Skid 7.6@3000 #SC30008DAF[/h]
$10850 + freight
[h=1]SC Series[/h][h=2]110v 7.6/2gpm @ 3000 psi, 200 degrees, 719cc Kubota Diesel Engine, General Pump[/h]
SC Series​
Rugged “Pro-tect-it” Frame:
Hydro Tek’s unique “Pro-tect-it” frame of 1¼”, heavy gauge steel, with durable electrostatically applied powder coat finish.
Stainless Steel Panels:
These rugged and durable panels offer lifetime corrosion resistance and protection of your valuable investment from the harshest environments. Keeps your machine looking like new for years to come.
SpiraLast™ Coil and Heating System:
A 12v oil fired burner is paired with the Hydro Tek manufactured SpiraLast™ heating coil for an efficient heating system. Robotically fused ½” schedule 80 steel pipe is cold rolled to protect the steel pipe from fatigue and the spiral coil is then surrounded by ceramic insulation and stainless enclosure with double-wall end caps. Check out our lifetime coil warranty.
Industrial Engines:
Efficient OHV gas engines with electric key start, low oil shutdown, and cast iron cylinder for maximum duty and performance. Some models equipped with a durable, water-cooled diesel engine with key-switch shutdown, for enhanced longevity and single fuel source.
Fuel Tanks:
Heavy Duty “roto-molded” rust free fuel tanks with fuel filter to protect against contaminated fuel. Extended run time (up to 8hrs.) eliminates interruptions. High capacity 8 gallon gas and 18 gallon diesel fuel tank decrease refueling and operator down time.
Total Relief Unloader - Remote Mounted:
Flow sensitive unloader allows pressure to build up gradually as trigger gun is activated eliminating “pressure spikes” and improving operator control and safety. When the gun is released, entire system pressure is relieved, enhancing system life and eliminating engine starting problems. The unloader is panel mounted eliminating heat failure and vibration. Balanced regulating unloader on 2-gun and 4000psi systems.
NEMA4- Water Tight Control Panel:
ETL certified to UL1776 Class 2, for use in wash-down area, exceeding Industry standards. Special Hydro Tek control box features easy to use controls and provides instant access to electronics. (SC36004D12Q n/a)
2 Gun Compatible:
Allows the operator to operate two pressure guns simultaneously, creating a multi-purpose machine, increasing efficiency and time. Unique split flow design balances pressure spikes. The adjustable flow feature also allows the operator to conserve water when needed
110v Diesel Fired Burner with On-Board 3000 watt Generator:
Provides automatic, high intensity ignition and reliable power for the heating system. Supplemental power outlets from the generator (GFCI Protected) offer the operator additional electrical power to run lights or accessories. (D12 models have an efficient 12V burner system that offers and economical alternative and still provides maximum burner performance - not compatible with auxiliary accessories)
Belt Driven Pump:
High torque, V-belt driven pump, low RPM, cooler and quieter operation for continuous duty performance.
[h=2]More Standard Features:[/h]
  • Burst disc technology for operator safety
  • Adjustable thermostat
  • Heavy duty gun and wand with nozzle storage and 50’ hose
  • Insulated quick couplers & 3 or more nozzles
  • Hour meters are included on all diesel models
