Take advantage of the savings in ordering 3+, 5+ or 10+ of the parts you use regularly!
Here's a peek at what you can save in bulk. Be sure to check out everything available by following the link to our store, http://shop.powerwashstore.com/
Part #
Description
Each
5 or more
10 or more
Legacy Brass 1/4” FPT Coupler
$3.36 ea.
$3.05 ea.
$2.75 ea.
Legacy Brass 1/4” MPT Coupler
$3.36 ea.
$3.05 ea.
$2.75 ea.
Legacy Brass 3/8” FPT Coupler
$3.94 ea.
$3.64 ea.
$3.34 ea.
Legacy Brass 3/8” MPT Coupler
$3.94 ea.
$3.64 ea.
$3.34 ea.
Legacy Brass 1/2” FPT Coupler
$11.81 ea.
$11.00 ea.
$10.25 ea.
Legacy Brass 1/2” MPT Coupler
$14.37 ea.
$13.25 ea.
$12.25 ea.
Part #
Description
Each
5 or more
10 or more
2746
Non-Adjust. Hi Draw Acid Injector 2-3.6gpm
$20.20 ea.
$17.20 ea.
$14.20 ea.
2747 Non-Adjust. Hi Draw Acid Injector 2.7-4.9gpm
$20.20 ea.
$17.20 ea.
$14.20 ea.
2748
Non-Adjust. Hi Draw Acid Injector 5-8gpm
$20.20 ea.
$17.20 ea.
$14.20 ea.
2715
Adjustable Stainless Steel injector 2-3.6gpm
$102.58 ea.
$88.00 ea.
$78.00 ea.
2716 Adjustable Stainless Steel Injector 2.7-4.9gpm $102.58 ea.
$88.00 ea.
$78.00 ea.
2717
Adjustable Stainless Steel Injector 3.3-6gpm
$102.58 ea.
$88.00 ea.
$78.00 ea.
2750
Brass Adjustable Injector 2-3.6gpm
$20.71 ea.
$17.25 ea.
$15.25 ea.
2751
Brass Adjustable Injector 3-5gpm
$20.71 ea.
$17.25 ea.
$15.25 ea.
2752
Brass Adjustable Injector 5-8gpm
$20.71 ea.
$17.25 ea.
$15.25 ea.
2755
Non-Adjustable Injector 2-3.6gpm
$17.95 ea.
$15.95 ea.
$13.95 ea.
2756
Non-Adjustable Injector 2.7-4.9gpm
$17.95 ea.
$15.95 ea.
$13.95 ea.
2757
Non-Adjustable Injector 5-8gpm
$17.95 ea.
$15.95 ea.
$13.95 ea.
Part #
Description
Each
3 or more
5 or more
Legacy 50’ Black 4000 psi – One Wire
$67.65 ea.
$60.65 ea.
$55.65 ea.
Legacy 100’ Black 4000 psi – One Wire
$108.70 ea.
$98.70 ea.
$88.70 ea.
Legacy 50’ Black 5000 psi – Two Wire
$79.02 ea.
$74.02 ea.
$59.02 ea.
Legacy 100’ Black 5000 psi – Two Wire
$131.29 ea.
$121.39 ea.
$111.29 ea.
