New water flow controller for water fed poles
Results 1 to 6 of 6
Thread: New water flow controller for water fed poles
    Default New water flow controller for water fed poles
    Check it out
    https://youtu.be/UGvRGhFZuuw
    Tony Evans
    Tony@anewviewia.com
    Call or Text 319-325-9475
    www.anewviewia.com
    Tony Evans
    A New View Exterior Cleaning
    UAMCC President
    319-325-9475 Call or Text
    tony@anewviewia.com
    Default Re: New water flow controller for water fed poles
    Any chance this video can be made to work? Would like to slow the flow to the brush a bit, I am aware of (GPM) works better but trying to existend the life of the DI cartridge. Also can you slow the flow of the inlet water or from the garden hose to the DI filter with out it causing damage or poor results from the DI filter? What is your opinion on dual DI tanks say two pro rinse in line, one as the slave filter and the other as a back up? Cost of the Ro system is out of my budget for now and the other item I run into is water consumption, folks treat the water as if it was gold and the waste water from an Ro system might raise some concers with clients even if I ran an exstension hose away from the unit. Thanks
    Randy Wahl
    Advantis Pressure Washing
    www.pressurewashingapw.com
    randy@pressurewahingapw.com
    Not sure why it's not working. I'll replace it tomorrow. Yes, you can run two DI units like that and you'll get a little longer use out of them that way.
    as for RO waste water you can run the bypass to landscaping or to your pwer buffer tank.
    Sent from my SM-T350 using Tapatalk
    Tony Evans
    UAMCC President
    tony@anewviewia.com
    Thanks for the help, look forward to seeing the video.
    Randy Wahl
    Sorry this slipped my mind. I'll jump in the office this afternoon when we're done working this morning
    Sent from my SM-G930R4 using Tapatalk
    Tony Evans
    UAMCC President
    tony@anewviewia.com
    Try it now Randy
    Tony Evans
    UAMCC President
    tony@anewviewia.com
