Results 1 to 5 of 5
Thread: Pure Water 101
    Default Pure Water 101
    A little pure water 101 for those thinking about getting into water fed pole window cleaning.
    There are two basic ways to purify your water.
    Deionized resin or multi stage filtration.
    Each has pros and cons. With few exceptions deionized resin systems (DI) are practical with source water readings of less than 150 parts per million (PPM), also referred to as total dissolved solids (TDS). Above that a multistage system with at least 3 components (carbon filter, reverse osmosis membrane, deionized filter) is a better option in companies planning on high water fed pole use.
    DI only
    Pros - tap water pressure operation, small footprint, simple set up
    Cons - Limited production in high TDS, single pole use only
    Multi stage (RO/DI)
    Pros - economical at all levels of TDS, multiple pole use from one system, flexibility of using RO only for non architectural glass surface cleaning
    Cons - larger footprint, more complicated set up, higher initial investment
    This is by no means a comprehensive discussion. It's meant simply to give some idea of factors that will aid in the decision on which set up is right for your business.
    Tony Evans
    Tony@anewviewia.com
    Call or Text 319-325-9475
    www.anewviewia.com
    https://youtu.be/BLBbO8DjLQU
    Tony Evans
    A New View Exterior Cleaning
    UAMCC President
    319-325-9475 Call or Text
    tony@anewviewia.com
    Default Re: Pure Water 101
    Good info, I had no idea. Thanks Tony
    www.accountabilitypressurewashing.com
    713.382.4944
    David Gatton
    Dgatton@accountabilitypressurewashing.com
    David Gatton
    Accountability Pressure Washing
    Good info canít wait to start using WPF.
    Quote Originally Posted by Jamie Schmidt View Post
    Feel free to contact me if I can be of any help.
    Sent from my SM-T350 using Tapatalk
    Tony Evans
    UAMCC President
    tony@anewviewia.com
    Definitely will Thanks.
