Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958
Force Field By Iron Man Arrie Parker will Host a Webinar Tonight 4pm PAC 7pm Eastern
Results 1 to 2 of 2
Thread: Force Field By Iron Man Arrie Parker will Host a Webinar Tonight 4pm PAC 7pm Eastern
  1. #1
    Default Force Field By Iron Man Arrie Parker will Host a Webinar Tonight 4pm PAC 7pm Eastern
    Join Live Webinar NOW!!!!!!!!!!
    Arrie will give all in attendance a Password for a vary Steep discount up to 2.5 Gallons.
    Look here for the Details or if your having problems Logging in Text Arrie or myself
    Arrie Cell 6787915344 Ron 4805225227
    Do not Call as we are on the call live. We will try to help
    This is really the only instructions.
    Go to this Link below and Insert your Email and Webinar ID: 127-837-755
    http://www.gotomeeting.com/webinar/join-webinar
    Example email you will receive telling you that you have registered correct.
    Thank you for registering for "Ron Musgraves Interview With Force Field's Chemical Engineer".
    Listen in as Ron gets to the bottom of claims that Force Field Nano Shield can protect for up to 20 years. Find out which materials Force Field protects.
    Please send your questions, comments and feedback to: arrie@ironmanpowerwashers.com
    How To Join The Webinar
    Sun, Apr 3, 2016 4:00 PM - 5:00 PM MST
    Add to Calendar: Outlook® Calendar | Google Calendar™ | iCal®
    1. Click the link to join the webinar at the specified time and date:
    https://global.gotowebinar.com/join/...4500/680189900
    Before joining, be sure to check system requirements to avoid any connection issues.
    Note: This link should not be shared with others; it is unique to you.
    2. Choose one of the following audio options:
    TO USE YOUR COMPUTER'S AUDIO:
    When the webinar begins, you will be connected to audio using your computer's microphone and speakers (VoIP). A headset is recommended.
    --OR--
    TO USE YOUR TELEPHONE:
    If you prefer to use your phone, you must select "Use Telephone" after joining the webinar and call in using the numbers below.
    United States: +1 (646) 307-1720
    Access Code: 491-269-072
    Audio PIN: Shown after joining the webinar
    To Cancel this Registration
    If you can't attend this webinar, you may cancel your registration at any time.
  • #2
    Default Re: Force Field By Iron Man Arrie Parker will Host a Webinar Tonight 4pm PAC 7pm Eastern
    Quote Originally Posted by Ron Musgraves View Post
    --OR--
    Hello We are live now
  • Thread Information
    Users Browsing this Thread
    There are currently 1 users browsing this thread. (0 members and 1 guests)
    Posting Permissions
    • You may not post new threads
    • You may not post replies
    • You may not post attachments
    • You may not edit your posts
