Does bleach whiten concrete ? Heard it did but don't know for myself. Thanks any info. anybody
cleaning the dumpsters everytime or do you charge separately for them as needed.
Do you always include dumpsters with 15 day restaurant cleaning
Do you do any work for apartment complexes (dumpsters, pigeon poop, etc)
What do you use to clean a "Kool Deck" pool deck?
Does a one legged duck swim in circles?
Thanks Ron for the info. just two more, do you apply it with the injector or spray it on with a sprayer? and do you leave in on the concrete or rinse it off ? Thanks
http://www.aldonchem.com/popup-ab-efflorescence.htmRon, or anybody have you ever tryed to remove stains out of the tile along the top of a swimming pool ? Thanks.
Hey ron! Back to this min 6 gal a minuite for flat work. I purchased a hotsy 1200 skidsteer 4.3 3500-4000 psi. From what little i have used it,it gets screaming hot and the pressure is quite powerfull to me.Basically what i could only afford.From what i gathered in your video's you recommend a min 6 gal a min for flat concrete work.Can a few more gal a minuite really make that much difference. Is it really cleaning it better or just faster.I could not see me holding onto a wand with more psi then that for any length of time. Also looking at those floor machines you hook your pressure hose to have a max 4000 psi. Do they make a floor tool to handle more psi or volume of water. I guess once i get out there i will figure out what my machine is capable of doing.Thanks!
I've done residential pressure washing for several years but I've got an offer to pw 50 gas stations. What kind of setup would be best for that type of work? Thanks.
A big one that does several per night is the answer WrightCleaning
Looking @ a used rig that has 5.5 & 8.0 gpm both 3500psi. I would think 8.0gpm would be great for flatwork & 5.5gpm for awnings, storefront, ect. I would think that would be more than adequate, right?
The horizontal surface is sometimes better to use a lower volume because more water can mean more pick up. Awnings and building are verticle cleaning and more volume can speed cleaning tremedously. More speed more profit in your pocket.
Keep in mind with this comes larger energy bills also.For Sidewalk cleaning no one will ever talk me into bigger is better. I have tried and have 8 gallons a minute we use for first time cleanings.
