Cigar City Softwash Supply - Spring Hill FL 34609, Sarasota, FL 34243
Kris Meyer
UAMCC Associate Member
Staff member
Kris Meyer
Staff member
🌟 Get Top-Notch Cleaning Equipment & Supplies with Cigar City Softwash Supply! 🌟
📞 Call 813-686-7638
📧 Email
🏢 Address 13112 Spring Hill Drive, Spring Hill, FL 34609
Shop Cigar City Softwash Supply Sale Collection
  • *1 Piece* Quick Connect Plugs
    • Size 1/4" FPT SS Plug - 1/4" MPT SS Plug - 3/8" FPT SS Plug - 3/8” MPT SS Plug - 1/2" FPT SS Plug - 1/2" MPT SS Plug
  • M5 Twist & Sharp Shooter Combo
    • 3-7GPM 8-10GPM
  • M5 Twist with Short Gun Ball Valve Swivel Combo
    • Shooter Tip Combo M5Twist & Davis Shooter Tip Combo - 3-4GPM M5Twist & Davis Shooter Tip Combo - 3-7GPM M5Twist & Davis Shooter Tip Combo - 5-6GPM M5Twist & Davis Shooter Tip Combo - 6-7GPM M5Twist & Davis Shooter Tip Combo - 8-10GPM M5Twist & Davis Shooter Tip Combo - 10-12 GPM
    • Short Gun Type ST-2305 Suttner Safety Orange Spray Gun 5000PSI Easy PULL - ST-2305 Suttner Blue Spray Gun - Suttner ST-1500 Gun - Suttner ST-2605 Spray Gun
  • Ball Valve Swivel Combo
  • *25 Pack* Quick Connect Sockets
    • Size 1/4" FPT Socket SS - 1/4" MPT Socket SS - 3/8" FPT Socket SS - 3/8" MPT Socket SS - 1/2” MPT Socket SS - 1/2" FPT Socket SS
  • *25 Pack Quick Connect Plugs
    • Size 1/4" FPT SS Plug - 1/4" MPT SS Plug- 3/8" FPT SS Plug - 3/8” MPT SS Plug - 1/2" FPT SS Plug - 1/2" MPT SS Plug
  • The Tuper Quick Draw Basic Unit
  • Pressure Pro 8GPM@3500psi Hot Super Skid Pressure Washer
    • Ships for free in 5-7 days
    • Standard Accessories Honda GX690, 8GPM@3500psi - Gun/wand assembly with insulated grip and quick connects - 50′ high-pressure hose w/ quick connects - Maxi-Flo 20% chemical injector assembly w/ quick connects - 4 color-coded QC spray nozzles - 1 color-coded QC chemical nozzle - !
    • Standard Options PKW003-C Wheel Kit - ESK016 Exhaust Stack Kit fits 16” Coil - FTK001 Float Tank Kit w/ High-Pressure Chemical Metering Valve - CCK015 On Board 15 Gal. Poly Fuel Tank w/ Carbon Canister - California Compliant Upgrade - MC-B145 Machine Cover Blue Poly Marine Fabric - Product Length 48 Inches -Product Width 40 Inches - Product Height 41 Inches - Power Type - Gas - Engine Brand Honda GX- Starter 12-Volt- 24 HP - 688 CC - Fuel Tank Size 12 Gallons - Consumer Engine Warranty 3 Years - Commercial Engine Warranty 3 Years - Hose Length 50 Feet - Hose Diameter 3/8 Inch - Hose Connections Quick-Connect - Spray Gun - Pump - Burner Fuel
  • DIY Honda GX390 5.5GPM@3000psi Pressure Washer Kit
    • Free shipping on all machines!
    • Honda GX390 Pull Start Gearbox - Comet 5.5Gpm Pump - K7 Unloader - 50ft Fierce Jet Hose Gun/Wand & Tips - Hudson Float Valve -M5 Twist Combo - Pressure Washer Plumbing Install Kit - 18" Hammerhead Surface Cleaner - Downstream Injector with QC's - 200' Legacy Pressure Hose - 6' Jumper Hose - 12" General Pump Reel
  • Scag Liberty Z SZL52H-24KT 52 inch 24 HP Kohler Zero Turn Mower
    • Description 52" Hero Cutter Deck, 24 HP Kohler® 7000 Series™ PRO - 725 cc displacement
    • FEATURES Proven Transaxles - Command perfection - Ogura PTO Clutch Brake - Easy Foot-Pedal Deck Lift - Contoured, Bolstered, High-Back Seat - Low-Maintenance Mower Design - High-Strength Steel Frame - Powerful and Efficient Engine Options
  • Scag Liberty Z SZL36H-20KT 36 In. Zero Turn Mower
    • Features STRONG, ADJUSTABLE CLUTCH FOR LONG LIFE - DEEP, FABRICATED, AND WELDED CUTTER DECKS - RELIABLE POWER, UP TO 24 HP - SOLID DESIGN FOR YEARS OF DEPENDABLE SERVICE - MORE UPTIME - SPEEDS UP TO 7 MPH - EASY UP, EASY DOWN - RIDE IN COMFORT
  • BE 8GPM@3500psi Hot Super Skid Pressure Washer
    • PART NUMBER: HW3524HA12V
    • Free shipping Powerful Honda GX690 engine - Belt drive - Industrial grade AR triplex pump - External unloader - Heating coil - The burner - Industrial grade accessories - Powder coated steel frame -Oil drain hoses. Ships directly from the factory
  • BE 8GPM@3000psi Hot Super Skid Pressure Washer
    • PART NUMBER: HW3024HG12V Powerful Honda GX690 engine with electric start drives the pump. A 55AH Marine battery is included. Belt drive system - Industrial grade General triplex pump - External unloader - Heating coil is ignited by a 12v Beckett burner - Burner can be turned off and controlled with the adjustable thermostat - Industrial grade accessories included - Powder coated steel frame with 1.5" OD roll cage -Oil drain hoses. Ships directly from the factory! Free shipping!
Kris Meyer
Staff member
Check Out CigarCity Softwash Supply Multiple Financing.
Click on the links below to apply.
Sheffield Financial - Apply Here!
Great rates for all business needs!
100% Financing available!
Up to 72mo Terms on certain equipment!
Clicklease Financial - Apply Here!
Great option for customers with under 600 credit scores
that may not get approved anywhere else.
100% Financing with 0 down.
No sales tax!
Up to 48 month terms.
First Citizens Bank Equipment Finance - Apply Here!
Formerly known as CIT
Rates as low as 5% for up to 72 months for businesses
2+ years old with great history. This is a traditional business
loan that reports debt exclusively to your business.
The entire purchase may be written off in accordance
with the IRS tax code 179. 100% Financing!
Minimum of 640+ credit score required. CIT is not
recommended for Startups. Rates are typically at 25%+ rate
and lower term with a higher downpayment.
For any questions, feel free to call our dedicated rep
Dustin Engstrom Lending Solutions Manager
Dustin.engstrom@CIT.com | 603 373 1919
Kris Meyer
Staff member
Kris Meyer
Staff member
🌟Shop CigarCity Softwash Supply Innovations
Unlock Revolutionary Cleaning Solutions!
💧Renowned for Revolutionizing Pressure Washing
with the Most Robust, User-Friendly, & Value-Packed Rigs on the Planet!
Guess What?
You Won't Believe What CCSS Has Up Their Sleeve!
🛒 CigarCity Softwash Supply Posted They Just Received a Shipment....
✨ Click Now to Explore CigarCity Softwash Supply Latest Innovations.
🔥 #InnovativeCleaningSolutions #UnleashThePower 🌟
