Hot and Mighty Has a New Enclosed Pressure Washing System With Wash Water Recovery
Tomdurbin
Hello Everyone,
This is to announce our newest member to the Hot and Mighty Line-up. The new model is a variation on our commmander series trailer. This unit is a closed loop recovery and recycyling system with our Hot and Mighty MCS-3506-OH6G skid package and can run two wands or one surface cleaner. It is designed for cleaning concrete in areas without heavy oil build-up. The total package out the door internet or UAMCC member price 23,700.00. I am making a video today and it will be up in about a week in our custom equipment shop blog at www.hotandmighty.com. I will be posting some pictures later today.
Tomdurbin
Re: Hot and Mighty Has a New Enclosed Pressure Washing System With Wash Water Recover
Trailer Specifications:
Manufactured by: Interstate 1
Cargo Trailer
Tandem axle 3500LBS PER AXLE
Dimensions: 7' wide X 14' length
Electric Brakes
Bargman Light Hookup
Curbside door
Roadside door
Exhaust through roof
Spare Tire
Always open vents
Pressure Washer Specifications:
HOT AND MIGHTY MCS-3506-OH6G
Hot or Cold water pressure washer
5.7gpm @ 3500 PSI or two guns each operating at approx 3.0
gpm @ 3500psi
Honda 24HP Gas Motor
Belt drive Tri-plex oil bath general pump
Special pressure regulating unloader for dual gun operation
Bypass line back to holding tank for longer running time in bypass mode
3600psi safety relief
2600 Watt 110v generator for burner system
Adjustable thermostat
High Pressure soap injection
Low pressure soap injection
Steam Valve
Three Way valve (easily switch from tank supply to fresh water inlet)
Hour meter
2 Heavy duty Hose Reels
200’ two wire 6,000psi high pressure hose
Heavy duty deluxe variable pressure wand with swivel
Eight quick connect nozzles
Three Hundred Gallon Water tanks plumbed with a dump valve for quick draining
Rotary nozzle
Spare parts kit
WASH WATER RECOVERY SYSTEM
Mighty- Vac MV23-285 cfm vac package with built in generator for auto pump out
High water shut-off switch to keep water out of your blower (critical)
Dot approved 30 gallon waste tanks with slide out pre-filters and auto pump out
Dot approved 15 gallon Sand catcher drums
Epoxy-phenolic lining for rust resistance
200’ crush resistant extra heavy duty 2” id vacuum hose
39” long sx 11” wide sandbags (just add the sand)
Two Cotton Mouth Wash Water Recovery Dams
21” Flat Surface Cleaner
WASH WATER RECYCLING SYSTEM FOR CONCRETE CLEANING LIGHT OILS
•Three bag Filters with 10” x 23” bags filtration graduated down to 5 microns
•Bag Filter Housing to be Fitted with auto-bleeder valves
Replacement filters (year supply)
Tomdurbin
Here are some pictures.
